65esl72 Johnson outbard, surging at high speed
Too Dogs
I replaced the fuel pump as, at that time it ran much better when pumping the primer bulb.
I removed and cleaned the carbs and noticed the floats were on an angle when inverted. Manual calls for 1/16" clearance and "parallell".
I checked and replaced a couple of fuel lines from pump to carbs; no leaks now.
I substituted a different tank and fuel line that worked on a 10 HP Johnson and the motor operated the same.
Compression; 135 PSI Top, 132 Mid, 132 lwr.
Idle mixture screw and seat looked good, high speed seat looked good (no high speed mix screw)
Question:
1. Could my problem be the floats not being set properly? As the floats were all angled, not parallel, is it actually possible to bend the metal arm and make the floats parallel?
2. Any other possibilities?
Thanks, Jerry
Joe Reeves
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
Too Dogs
Joe Reeves- thank you for your reply. Adjusting my floats and setting the (3) SSscrews should solve my problem?
Also, I see rebuild kits with different parts; some have floats, others don't. What do you consider essential parts in a rebuild kit? Thanks, Jerry
Joe Reeves
1 - Adjusting my floats and setting the (3) SSscrews should solve my problem?...... 2 - What do you consider essential parts in a rebuild kit?
1 - Whether those two suggestions will cure your problem depends on anything else being wrong with the engine. However, those two areas are critical and should be looked at.
2 - Carburetor kits normally have an assortment of parts fitting various carburetors, necessary to avoid having a zillion kits available. Essential parts would be anything in your present carburetor that should be returned to new condition..... float, float N/V assembly, just to mention two.
