reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I picked up a boat the other day which was garage kept for many years, probably since new. The boat was parked after the lower unit seized many years ago. I pulled the lower unit, and gave the motor a good once over and a compression check. All looks good.
Now for the question, I have a few good used mid to late 60's Mercruiser lower units that sure do look the same other than the drive shaft. The lower units were all from Merc 110 and 120 I/O drives.
Can I swap drive shafts and use one of them on this motor?
The prop hub and housing diameter is the same, the bolt pattern looks the same, and the shift linkage is the same. I guess the main question would be gear ratio and the ability to install the outboard drive shaft in the I/O lower unit?
