Hi All,
Have been working on my 3 hp Johnson and am stumped where to go next. The motor had sat for a number of years. It had no spark on one of the coils so I replaced it with new one. I also replaced the condensors and points. Removed the carb and cleaned and installed carb repair kit. Now has really good spark and it does start but runs for only a minute. Acts like not enough gas but checked bowl and it was full. The only way to keep it running is to keep choke pulled out about half way and then it still might run for a minute or so. Water pump works great too.I have removed the carb several times and checked it and can't find anything. When it runs it sounds great. This is model# jh19a any help would sure be appeciated. Thanks John
