Hi!
I have a 1964 3 hp Johnson that sat for quite a while.Model # jh19a. I took the carb apart to clean out the varnish and dirt and noticed the needle that shuts the gas off when float bowl is full does not have a clip on it. Is this normal. Every other carb I have worked on had a clip that connects to the float. I would like to find out if it does not have a clip before I put it back together. Thanks for any help. John
