Re: 63 Johnson 18hp won't shift
Glad to here it was something so simple!<br />I don't think it'll be a problem. That's just the exhaust chamber in there. <br />If you lay the engine on it's back and shake the lower unit a bit, the bolt may just drop out the exhaust. It's worth a shot anyway.<br /><br />If you want get it out, you simply unbolt the lower unit (4 or 5 bolts), disconnect the shift rod coupler and pull the lower unit off. The driveshaft will come with it. To reassemble, lightly grease the top of the driveshaft and replace the oring there if it's worn. Then install the lower unit lining up the shift rod, the driveshaft and the water tube. It's a bit of a hassle, but not a big deal.<br /><br />But I doubt it would cause any sort of problem to operate it for now with it in there.
