utah lakes
Thread starter- Joined
- May 31, 2016
- 8
I have two wires coming through the wire harness into the engine that are not attached to anything. Are those the leads that have to be attached somewhere to wire the Tach? The Tack is an old airguide P-5079 or 653 if that matters. the harness has 4GA red and black, brown, white, and 2 black, those are all attached. just the two others are unattached (white and Blue) Also as I am rebuilding the Harness any Ideas on wire shroud to clean and protect, Hate to just tape the hell out of it...
I don't have the the sending unit or regulator for the Tack and from looking at old air guide tack on ebay I have noticed some have it and others do not. Will that be required?
When I install the tack wires at the dash will that get wired through the ignition switch or perhaps direct using white and blue all the way to the motor direct to tach? Any help would be greatly appreciated.
