Nah, easy job. Good to look at a parts diagram, though. 6(?) screws from underneath holding the powerhead in place. Will need to remove the throttle tower -- look for a tiny spring down at the base (easily lost). The top of the driveshaft has a spring and seal assembly, and should pay attention to the assembly order. The shift shaft under the powerhead is threaded, held in place by a couple of nuts and a star washer, as I recall. When disconnected, will slide out with the lower unit.
