60 hp mercury 3 cyl
ruder
I have a 60 hp mercury that I can't make heads or tails about the serial numbers, can you help?
serial # 6129438. Thank you
carholme
Re: 60 hp mercury 3 cyl
ruder;
Are you sure about the s/n as 6129438 comes up as a Merc 25hp.
Gerry
gwukena
Are you sure that is the right s/n? 6129438 comes up as a 1983 25 hp, 6429438 comes up as an 1984 60 3 cyl. When searching by s/n add a zero before s/n you have
Gary
ruder
Gary
Yes this tag on the motor hasn't been changed, I have had these problems before with some of the older serial numbers.
With the colors on the band on the cover black with yellow stripes I assume that it is a 84 or 85 but I would like to know how to get the serial numbers correct.
I boats says this number cannot be found. It is the right number. Thank you
ruder
I checked the serial number through ********** and that number could not be found even when adding o before the first number. Thanks Gary
ruder
WELL
I am more senial than I thought, I checked and the numbers are 6429438.
I guess I am going to have to have someone to lead me to the lake and go fishing.
Thank you for all your help.
ruder
Thank you gerry everything checks out, Thank all of you that have responded.
Merry christmas to all of you. Ruder
