jjs05dodge
Thread starter- Joined
- May 16, 2007
- 1
hello i am new hear i hope someone can help me. i have a 2005 merc 6 hp outboard. the motor ran great last year, but now it won't run. I can get it started and it will run at a idle, with the throtle in the perfect place. if i give it any throtle it will die. I cleaned the carb and still no luck, thinking it was still a carb problem i bought a new one, and still the same problem. I have sprayed gas in the carb while running and it kills also took the spark plug out and put gas in cylinder it will still run the same. i also replaced the bulb no luck. the pump will pump gas. I did get it to pick up rpm just a little once or twice. also has ran at full throtle but still idle speed. could thid be a advancement problem or something electrical? any help would be great. thanks sorry for the long post.
