Tim Frank
- Jul 29, 2008
- 5,352
1) Gear shift rod bushing and seal. The OEM manual is not as precise on this as I might have thought. There is a brass bushing that guides the shift rod as it exits the gearcase...it goes in a bore that also contains a rubber o-ring...which is sits between the bottom of that bushing and the bore bottom-shoulder. There is no real instruction on reinstallation.
I can press in a bushing with the best of them, but how critical is the compression or non-compression of that o-ring?
There was no real wear on that bushing, I was just going to replace the o-ring. The tech at the dealer where I bought the parts said that the bushing could stay in place....I could fish out the o-ring and reinstall a new one.
Obviously a job for a seasoned pro because I got the old one out easier than i expected, but getting the new one back was going to be more of a challenge than I was prepared to deal with to save a $6- bushing. That o-ring was very thick and not very pliable. Would have been a real blood pressure raiser.
Ordered the new bushing, ran a 5/16-18 thread into the old bushing, pulled it and it is all downhill now except for the clearance between the bushing bottom and the o-ring....if any. I can just reinstall to "about" the same depth if nobody has a better idea.
The question is, should the bushing be inserted: 1) to "snug up to" the o-ring
2) to actually compress the o-ring some amount....and if so how much....3) something else.
Since the manual is non-specific on this, and it is just the shift lever...little movement, it probably is not a critical issue, but there had to be some design intent and it would be nice to maintain that.
I have measured the depth of the bore, the thickness of the bushing, and o-ring, and it appears that in the original positions there was ~ 0.100" clearance between the bushing and the o-ring, which means the oring could move in the bore. That just seems odd to me....
Any ideas?
Any ideas?
