58 RDE19 35 hp throttle linkage help
tashasdaddy
appears the key is broken, of the lower part of the linkage, will not bring back to idle or take to wot. how to repair or part number. also starter is bad, got 3 cranks, and that was it. removed going to try to have rebuilt.
Joe Reeves
Re: 58 RDE19 35 hp throttle linkage help
If you're saying that the nylon pin (304155) is broken and doesn't move the vertical throttle arm, remove the top two screws and the related linkage from the vertical arm and lift it up and out so that a new pin can be installed.
tashasdaddy
thank you, Joe, got it out & ordered, found shop to rebuild starter.
Scaaty
I just sold to a guy in Canada all that you need! Oh well..​
tashasdaddy
gee thanks, Robby!!!
Scaaty
Anytime..next time I sell something, I'll let ya know a day later if ya need it..:D
