tim thompson
Thread starter- Joined
- Jul 6, 2010
- 53
I assume the impeller housing has gasket but the only information obtained is just replace the impeller. Does anyone know this motor specifically(RDS 20? When I receive the impeller I will find out the answers about gaskets and o rings I suppose. How do you disconnect shift rod? I pulled 2 screws plate and there is another plate in there with two bolts holding it on. I've looked at all threads on impeller replacement but none are specific to this motor. Thanks
