58 evinrude fuel system
HighTrim
Re: 58 evinrude fuel system
2 barb pump? Which one?
Likely the pump just screws onto the bypass cover. No fitting required, just a gasket. Unless you got a pump that I am not envisioning.
lymanboat15
The pump is a 2 barb pump #18-7352 sierra do i just hook up the two fuel line
HighTrim
Yes it bolts to the bypass cover, with the gasket that came with it.
Then, you install the 2 fuel lines, 1 in and 1 out. Simple and easy.
HighTrim
you will have to of course follow F_Rs instructions about tapping the 2 holes as well so you can mount the pump. See post 15
lymanboat15
Know I understand what the gasket is for like I said I was making a biger project than it is .Will do on taping the holes thanks again for all the help going to try and start moter next week waiting for new mercury switch
pro-crastinator
Here's a pic of the air line nipple on the carb. Compared to a 1/4 inch bolt to get perspective.
Notice fine thread.
lymanboat15
PROP1.jpgPROP1.jpgPROP1.jpgPROP1.jpgPROP 3.jpgThis is a prop off 1959 evin rude electric shift the holes don't line up is it because it is from electric shift please se attacheed pictures thanks ALEX
No such thing as a 1959 electric shift.--------One hole would be for the drivepin and the other for a cotter pin to keep the cap on.------Note ---there is no difference in a 40 HP electric shift prop and a standard shift prop.--Picture shows the standard shift lower unit.
lymanboat15
Do you know why the prop doesn't fit. I mrnt 69 Johnson
geoffwga1
Have you already done a compression and spark test,If not that should have been the first thing before considering any thing else.Be areal bummer if you do all this work only to find you have no or poor compression #s.Also carb overhaul if the motor has been sitting a while.
lymanboat15
Did the compression first thing 95 both cylinder. Don't know about carb will find out monday.
lymanboat15
Well I have plenty of spark that is really a surprise considering the shape of the rest of the motor. Waiting for gas line hose then the big day. So far I have about 125.00 invested not bad if the motor runs.
lymanboat15
Finaly got all the parts for the motor on sat.Motor tried to start but would not keep running kept flooding out removed carb needed cleaning and one bolt was loose mounting carb on engine.I ordered rebuild kit today next try on wednesday.Going to work on electric start while waiting for carb kit starting by hand is a killer. Thanks for all the information on fuel pump worked good so far.
