kbait
Thread starter- Joined
- Nov 13, 2007
- 2,488
This one had been sitting for 15 yrs. Cracked coils and ignition taken care of. Barrel tested and it ran good, but little water output at low idle, better-not much at high idle (Barrel water just below exhaust port.. plenty deep). Water splashed on head boils. So I figured the impeller was toast. Pulled powerhead and dropped lower unit to change it out. Impeller had taken a bit of a set, but still looked ok. Changed it with a new one and put it back together (pin installed correctly and watertube inserted into grommet). Water tube was clear. Test run, and even less water out port in back, no matter rpm's, and overheat again. I didn't actually pull the impeller plate when apart, but it looked flat. Blew canned air in water intake and I could feel it coming through that plate, so I figure intake is clear. I usually blow air up the watertube before installing lower unit, but this one has the powerhead removed so you can't really check the flow through the powerhead through that tube.
Any ideas? I'll pull it apart tomorrow and spin the driveshaft while the L.U. is in a bucket of water and make sure it's pumping ok. Anyone know how to check the water passages in powerhead when powerhead is removed? I blew through some ports when I had it off, and nothing appeared to be blocked.
Thanks!
Thanks!
