FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
quick question, when using the mikuni pulse pump for this conversion why can't you just run the air outlet for the old pressure tank to the air/pulse inlet on the pulse pump? thanks
The pump needs a pulse, alternating pressure and vacuum if you will. The air only provides pressure, there is a check valve that prevents the pulsing. If you remove the check valve on the reed plate it "may" work, I cannot really say. Rick
