57 Fastwin 18 Carb Problem ?
peacemaker48
I've just finished a second carb rebuild along with points and condenser, new gas lines and inline filter . The tank test was inconclusive. Lake tested it on Fri. and the results were mixed. The motor started on first pull and ran OK on low speed idle after a minor adjustment ( it had on intermittent chunk or cough ) . After passing the no wake sign I slowly opened up the throttle and the motor begin a shutter or miss. The feeling I got was only running on one cylinder. This only lasted a few seconds (2 to 3 ) and at that point it picked up the gas and began to run great . I did some fine tuning on the high speed control and clocked my speed at 21 mph ( as good as it's ever done ). This problem seemed to stay with me thru the running however it did seem to improve somewhat. The lull between low power and full became less but not a smooth transition. Also I'm using the original 6 gal cruse-a-day gas tank ( very good pressure ) and have to kill it with the choke. Thanks for any advice.
F_R
Honorary Supreme Mariner
That transition may be because of high and slow speed needle adjustments, or because of improper throttle pickup point, OR it may be somewhat normal. You have to understand how motors were in 1957. A certain amount of "loading up" of excess fuel in the crankcase would result in a bit of blubber when you started to accelerate. Once the excess fuel blows out, it should run smoothly.
So...it's hard to say from here if there is a problem or not.
oldboat1
sounds close. Jam nuts on the carb needles have to be snug enough to keep the needles from vibrating loose. It sounds like the shudder when throttling up might be rich running, not lack of fuel. Might want to lean out the h.s. mix a bit (clockwise). You would then go back and readjust the l.s. mix (probably leaner) to look for smooth low speed and throttle up. Sneezing is too lean.
Again, though -- sounds close.
flyingscott
After the motor is warm you can lean out the low speed needle more. Your final running adjustments need to be made after the motor is warm,
peacemaker48
Flyingscott, are you saying that the low speed idle setting effects the high speed settings during throttling up as well and including open throttle . And do you adjust LS and HS each trip or do set it and forget it letting it warm on its own?
F_R
If you have it anywhere near close, next step is to do final adjustment on a boat, on the lake. Run motor at wide open throttle, in gear, and turn the high speed knob slowly to the right till it begins to lose power. Then turn back to the left, till it regains power. Now slow down to idle speed and do the same with the slow speed knob. With this one, it usually will sneeze and possibly stall if too lean. In any case, turn it back to the left till it stops the sneezing.
It won't hurt to do a repeat check to see if it is at optimum. Once it is right, you can pretty much forget it. However, slight readjustments may be required with changes in air or lake temperature, or altitude.
Truthfully, we make it sound way too complicated. It isn't.
Yes, there is a small amount of interaction, but do it as I just described and don't worry about it.
oldboat1
What's the status on the electric conversion, peacemaker? (It sounds like you might have it dialed in to the point where pull starting is going to work for you.)
In addition to adjusting idle mix (or really in combination with it), you also have the idle stop screw. If choking to stop, you might be able to back out the screw a little. Cold starting on mine works best with a low idle setting, and conservative use of the choke.
peacemaker48
Thank you for that ob1. Yes the pull starting is no longer an issue with a one pull start and wearing a brace on my right wrist helps as well . I will try the needle stop screw out a little. Do you think the packing nut setting would make a difference? Also just got back from the lake and I'm going to try downloading about a 33 second video. Tnx agn
oldboat1
packing nut is probably what I call the jam nut (maybe technically a gland nut). Anyway -- snug enough to hold the needle from rattling loose; think that's about it, if talking about the same piece. Will look for the video (like to see success). Glad you have it up and running.
oldboat1
Well, optimistically -- think the carb is doing its job.
But could have a clutch dog issue. Could be an ignition miss. Could be internal.
and maybe completely off base.... need additional opinion; I'll defer to a better ear. Video is helpful.
flyingscott
That is not a lower unit problem looks more electrical. Look for wires rubbing re-check your points and how did the coils look and check the insulation on the plug wires. Re- do your link and sync
peacemaker48
Link and sync ??? If your talking about throttle adjustment I did't touch it or change anything. I may have left the points a little wide. Does it sound like a wide points gap?
Point gap is easy to verify.-----Use a timing light and aim at the 2 vertical marks on the magneto plate.-----Check both leads.-----Does the timing mark on the flywheel show between the 2 marks ?----Yes or no ?
peacemaker48
I should have said that the coils look good ( not points , their new ). Racerone thank you for that . Before checking with a timing light ( which I don't have ) I'm going to check the points first as I think I may have left them a little wide. If that doesn't fix the problem I'll beg , borrow or steal a timing light.... and follow your clear instructions.... Tnx agn
The actual point gap does not matter.-------What does matter is the exact time that they open.--------Usually at 0.020" gap they will fire between those 2 marks.----Elegantly easy to check with the timing light.
58rude
There is a video on YouTube that shows you how to set them with a VOM. Very easy to do.
