No Title
First off, Thank you everybody for all the help/knowledge, I might have a new hobby - learned a lot about this motors mechanics with your help and know where to go if I ever have any questions. I'm still not 100% that I truly fixed this shifting issue but seemingly got it figured out last night when tinkering. Lindy46 --> your "gravity is working against you" comment struck a chord, after hooking up the LU for about the 3rd time I finally told myself that the brass coupler just isn't going north enough to engage forward gear when using the shifter, thus leaving it in neutral. But when I put some upward pressure on the coupler with a screwdriver through the peephole, it engaged into forward gear perfectly. I feel dumb saying this, kind of a newbie mistake here, but I completely overlooked the lit up bolt in the pic as most of my attention has been on the LU. That bolt was essentially "fall out" loose all along and once tightened the linkage starting working perfectly w/o any encouragement through the peephole. Still waiting for the parts schematic but ordered orings/seals/parts today in hopes to get this motor on the lake by Memorial Day!!! Next step is the bucket test and then a good degreasing/clear coat to save the patina on this old girl!!!
Never again will I make it to the lake, have this problem, and head home in disgust again boys - Thank you All - my apologies on the rookie mistake/overlook.
