56 7.5 johnson
dtruck
Ok, here's the deal I have done everything in the topsecret file twice on decarbing motor.The best compression I can get out of her is 62lbs on both cyls.Seems to run like a top though, no problems at wot,idles pretty smooth all the way down to nothing,has very good response on a hole shot.Any wisdom on compression?
lindy46
Re: 56 7.5 johnson
That compression should be fine. If it runs good, that's all that matters.
dtruck
Re: 56 7.5 johnson
Thank you, just concened it was too low
JB
Re: 56 7.5 johnson
That's fine for a rope start engine.
dtruck
Re: 56 7.5 johnson
Great, guess i'll hang her on the wall till the lake thaws
1946Zephyr
Re: 56 7.5 johnson
If you get matching compression numbers, between the two cylinders, that is most important. 62 psi is pretty good. Your fuel mix should be at 24:1 ratio. Great little motor. I hope you enjoy it:D
