55hp chrysler electrical problems
wrephs
can anyone help i have a chrysler 55hp motor i cant start it with the key when i go to turn it on i can here the choke hit that is working i also here the solenoid click all the wiring is right on the key switch. i can start it by jumping the solenoid with a wire and everything is ok i have bought a new solenoid for this motor and nothing it does the same thing i have a book about this motor everything is hooked up right. next when i plug the battery i notice that the second coil on the bottom get real hot i tried to call boat mechanics some dont even help i dont even know how to use a volt meter to test it myself please help
eurolarva
Re: 55hp chrysler electrical problems
Welcome to iboats. Not sure what you mean by second solenoid. There is a choke solenoid and the starting solenoid. Take the starting solenoid off the motor and clean the bolts that it mounts to. Clean the area where it touches the motor. This starter solinoid uses a body ground which could be your problem. Clean the negative and positive leads to the battery so they shine, Clean the lugs on the battery. Clean the positive lead to the starter. Chances are you have a loose or dirty connection which creates resistance and will create a voltage loss. That starter will need almost everything that battery can put out and any corrosion can limit the amount of voltage getting there.
Alexey
Hi Everybody!
I bought an 55 hp Chrysler form year 1974. Type is 554HG Serial: 3079. I'm from eastern Europe, I use the motorboat on the river Danube, but now there is still a russian (soviet union) made motor on it, but wanna change it to the Chrysler. I havent got ignition key and original chrysler Control Box Throttle Shift. Im gonna use it with a Yamaha control box. The price of the outboard was a joke, but have some problems with it.
1st: the waterpump (impeller) is broken, i need a new, but in Hungary i cant buy it :-(
2nd: I dont understand the electrical system, the engine doesnt product spark, and the cables are different from the electrical shematic i downloaded. Can anyone help me pls?
Couple of photos:
Alexey
more photos:
Alexey
You can see the end of ribbed shaft, the old impeller
