55hc won't idle, need a lower unit case also
jrwhites
OK here it goes. Start it up and runs for a second, and i mean one second. The carb seems real clean, no adjustment screw on it. Compression is good, plugs look perfect. I can rev the motor up and it runs fine. It's getting fuel. Now i guess i need to pull the fly wheel and check the point gap? OK how do you actually check timming on a outboard. <br /><br />Also anyone have the lower unit housing they will part with. I dont need gears or anything. Mine has a crak in it. Thanks. :D
The Marine Doctor
Re: 55hc won't idle, need a lower unit case also
I have a used one at work I can part with. <br /><br />Email the details.<br /><br />marine.ron@shaw.ca<br /><br />TMD
12Footer
Timing is check just as it is on an auto. (pickup on plug wire #1, return on plug #1, power (if powered type timing light). But the timing rarely moves on these engines, and will usually track thru the entire power band, unless it has been moved.<br /><br />Before pulling the flywheel, check the compression, as it is a symptom of low compression also.
