MiOutboarder
Thread starter- Joined
- Oct 22, 2014
- 30
Hi everyone, I finally got the QD-15 I've been working on up and running. The problem is, when I took it out on the boat to try it out, it acted like the gears would slip into nuetral whenever I throttled above the stop position. Then when I would throttle down to around the start position again it would act like it kicked back into gear. Any thoughts about what is happening? Also if anyone has a link to how to change the impeller on this fine beauty it would be greatly appreciated.
Thank you
Thank you
