54 johnson 10 hp gear oil seal?
Bnecaise74
Need some new seals(o rings) for the lower end where you change the gear oil. You guys know where I can find them or an up to date number or size I can get to fix it. Thanks!!
Daviet
Re: 54 johnson 10 hp gear oil seal?
311598 will should work for you, check with your local dealer.
