I have a 2000 50hp evinrude efi. I've had issues with the fuel system for two years. I've replaced all the fuel lines the low pressure pump and the high pressure pump. The motor will run flawlessly for a while then just shut down and won't start back. The high pressure fuel pump will not run during this time. I bypassed the ecu and wired the pump to a toggle switch. Will I cause any issues with the functionality of the ecu or cause any problems with the motor itself by doing this?
