50hp evinrude efi
rob2032
I have a 2000 50hp evinrude efi. I've had issues with the fuel system for two years. I've replaced all the fuel lines the low pressure pump and the high pressure pump. The motor will run flawlessly for a while then just shut down and won't start back. The high pressure fuel pump will not run during this time. I bypassed the ecu and wired the pump to a toggle switch. Will I cause any issues with the functionality of the ecu or cause any problems with the motor itself by doing this?
Fleetwin
That engine was made by Suzuki, if it is a Four Stroke. You may try that section.
gm280
:welcome: to iboats rob2032. Nice to have you aboard...
If you disconnected the high pressure pump from the ECU before applying a switched power to it, then no, it will not hurt the ECU. But that also doesn't solve your problem either. It is a work around that surely isn't the best way to solve your situation. You need to figure out what really is the problem and fix it. Then you can boat around without any issues. JMHO!
