50hp 74' Johnson Crankshaft Bolts
Chrisravosa36
I cannot figure out how to get these bolts off!!! I cant deem to find the right rocket, any tips? It looks to be 9.5mm but when I put it on, its to loose? Is there a special tool?
Chrisravosa36
Cant seem to get it to budge at all? Any tips? I tried some heat, and then some PB.
F_R
Honorary Supreme Mariner
They are TIGHT by design. Get meaner, they will come out. Don't heat them! You need a pretty high quality socket to stand the strain. Most of us have broken a socket or two.
BTW, the installation torque spec is 348-372 INCH pounds. You must use a decent torque wrench. I don't consider a foot pound wrench to be accurate enough. That's only 2 ft pounds tolerance.
James R
Try using a bar or torque wrench at least 14" long. They break free easily then.
Chrisravosa36
I USED A 24' TORQUE WRENCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ha but I really did, not a single one even bugged on me....
A 24' wrench seem too big.--------I use a sn***n 12 point deep socket.-----Used it so many times that it wore down.---Ground off just over 1/8" and it works just like new again.----Never a problem !
???---the points wore off inside the socket.---Ground off the worn bits and the socket is like new again.----Used this socket on hundreds of these bolts , taking them off and installing them.---Never a problem !.
Chrisravosa36
Oh ok, I thought you meant the bolts, thats what Im having trouble with, they like to slip very easily.
????--These are "high tensile alloy " bolts.---The material has a strength of around 180,000 PSI---Not likely to wear the points off the bolts with a quality socket !
Chrisravosa36
Ok, so it must be my socket, how did you grind yourse down?? ALso, are husky sockets anygood, thats what ive got.
