50 hp forse 89 water pump help....please
criley
50 hp forse 1989 modle#507x9a 2 cylinder us marine power....... just fixed the issue that i had with the spark and now no water is spitting when i start it..... water pump not working....al so just replaced the lower end i have read the book front to back and cant see what im missing please help if any sugestions:confused:
tater76
Re: 50 hp forse 89 water pump help....please
When you say you replaced the lower end do you mean lower unit? Did you replace the impeller inside the lower unit?
criley
yes im talkening about the lower unit and i replaced the shaft and the lower unit not the water pump tho i used my old one cuz it was fine i thought ....my impeller looks fine it still has the bubles on the ends:confused:
criley
help me please i will return the favor if i know anything u need
huskerdaninva
Are you positive the key or pin that secures the impellar to the driveshaft is fitted correctly? Perhaps the impellar isn't secure to the driveshaft? Just a thought...
tater76
Huskerdan is right about the little pin that drives the impeller. It is small, and the one in my 50hp lower fits loosely, so I could see it falling out upon installation. It is a good idea to change your impeller every season, as this is cheap insurance. Did you lube the old impeller before you reused it? If the impeller checks out you may look through some recent threads about 50hp's overheating. It seems that some folks are finding the cooling passages filled with deposits that block water flow. One last thing, are you using muffs or a barrel to test it? sometimes the round muffs don't work great, and if you have it in a barrel fill it up to or over the cavitation plate.
wirenut75
Did you position the vanes of the propeller in the proper direction?
