Hi all,
Just put the boat in the water, and while the engine started up great, it was soon very hot smelling. A quick check revealed that no water was coming out the water check hole.
I shut the engine down, put up the sails, and sailed around a bit with the cover off the engine to cool it off.
I then sailed over to the slip, dropped the sails, and started the now cool motor. It quickly heated up again -- same problem.
My motor is a Honda 5hp 4 stroke. Vintage ~1989.
Any ideas? It ran fine in the fall, so I doubt there is a plug in the intakes. I'm wondering about an impeller problem, but don't know how to check that. Also, the manual says "faulty thermostat", but I haven't a clue where that is on this engine.
Thanks for any advice.
Boris
Boris
