5.7L GSi idleing issues DON S and others help!
sasada
I have a 2001 5.7L GSi pefs serial# 4012044349 3869059 that overall runs very well and most of the time idles right at 600-650rpm. However, every now and then (mostly when you dont want it to) it will idle at about 1000-1100rpm. I KNOW it is not that throttle or throttle body butterfly is sticking. Sometimes i will start it up and it will chug a little bit at idle then kick up in RPM. I can burp the throttle and it still will only come back down to the 1000 range. I can kill the engine start it back up and it idles down in the 600 range just fine. Sometimes i can be running across the lake and bring it down to idle and it runs up in the 800rpm range and if i put it in neutral it goes to the 1000-1100 range. Then i can kill to motor start it right back up and it will idle where it is suppose to at 600rpm. Rarely i have to kill it and start it a couple times but it will idle down and run like nothing is wrong at all. It can get really annoying when idleing along though a cove or when tightening up the rope on a tube if it does not idle down. Any idea what gives????
Don S
Re: 5.7L GSi idleing issues DON S and others help!
Get it hooked up to a diagnostic computer and see what is going on. it may not set a trouble code, but you can verify the sensors are reading correctly.
sasada
Obvioisly things change in an instant but as of a month ago it was not throwing any. There is only 1 Volvo service place in my area. Does it have to be a special marine type code reader or is there other types that work? Thanks!
sasada
Automotive readers do not work on marine engines.
One of these is the way to go. http://www.rinda.com/marine/mtspec.htm#techmate along with the OEM Service Manuals and you should be able to find your problem.
OUCH! $4hundy just for the scan tool! I guess one could look at it both ways if it paid for itself or not either way it means spending lotsa $$$. :eek: Maybe i should just take it in and have it scanned? Think im gonna call Troy down to the shop and see what they charge to put in on the scanner. I know auto places around here get $100 just to hook it up!
Don S
You have to have the tools if you want to work on these EFI engines.
