5.7gi 300r
jaytintinger@q.com
any one have a breakout of the engine wiring plug for a 5.7gi Volvo penta? color code don't match especially purple ignition. trying to bench run to verify condition. was told purple for ignition. no purple. there is black with purple stripe. tried it ,does nothing..Red has power and fuses have power. cranks fine with a remote starter switch. Any advice is appreciated.
fetch
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
fetch
Ayuh,..... Don't have yer answer, But,.....
Put 12v power to the (+) tiny terminal on the coil, 'n the motor can be started, or recheck the plug to see which pin-out is the ignition pin,....
All wiring color code is standard - however the wiring schematic is in the FACTORY service manual.
American Boat and Yacht Council Standards
COLORITEMUSE
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
BrownGenerator ArmatureGenerator Armature to Regulator
BrownPumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
GreyTachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
OrangeCommon FeedDistribution Panel to Accessory Switch
OrangeFeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
PurpleInstrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
RedPower FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
YellowGroundNegative / Neutral Main Return
Yellow w/RedStarting CircuitStarting Switch to Solenoid
jaytintinger@q.com
Thank you sooo much. I am afraid to jump straight to the coil with the electronics and computer. Do it all the time on conventional systems
alldodge
Have come up empty at boatinfo, the manuals are not that new.
Also come up empty trying to find VP 14 to 10 pin wiring, or even a newer harness which uses the 14 pin connector. I'm still working on it but come up with some guesses and maybe some others can fill in some of the blanks. Double check my colors and such with your connector
1BlackGround
2GrayTach
3TanAnalog Water Temp
4Tan/BlueWarning HornTan/Black ?
5Pink12V to motor
6Red/PurpleFused 12V Main Pwr
7Yellow/RedStart
8BlueOil Pressure
9Green/White
10Brown/WhiteTrim gauge
11GreenFuel Pump
12Blank
13Pink/Gray
14Black/White
This is Merc 14 which is used with smartcraft
alldodge
A bit late but they do make a 14 to 10 pin converter. I didn't mention it because thought you just wanted to start it before install
jaytintinger@q.com
I still don.t have a purple wire. can any body look at the pictures and advise which is the ignition?
have you looked up your wiring schematic in the manuals that I linked to in post #4?
alldodge
I looked for the schematic before my first post at boatinfo but could not find it. Maybe someone can find it and post a link
Its probably similar as the GXI, and this motor uses a Pink/White which is powered up by the main power relay. Find this relay and there should be a
Red (fused power)
Pink/White (switched power)
Black (relay coil ground)
Shows Purple but may be something else (energizes relay)
If all else fails applying power between pins 30 and 86 should power up the ignition. Applying power should show power to the coil to verify the connection is correct
