5.7 tune up specs
lynnboy021
ok so i have my motor apart cuz i put in new head gaskets and goinging to install new lifters and spark plugs. my ? is manual says timing should be at 8 btdc and dwell at 29+-2 point gap at 0.018in and valve lash at 0 then 1 turn (yes now i know Don S) o lash then 1/2 turn and last how many qts my motor takes? book says 5qts w/out filter and 6 w/filter? my dipsick i think its the wrong one cuz it wont fit oh and my dipstick tube bolts under the oil pan so anyone know where i can get a dipstick for a omc 5.7 1988? just asking to see if thats the right tune up or you guys have better specs...
lynnboy021
Re: 5.7 tune up specs
well just for the timing light with no advance is only 15 but if i want the advance its 28. i think sometimes you have to set advance timing or something so that $28 timing gun can do it but the $15 cant.
Joshua Nichols
I don't think you need the one with the advance... They are cool if you run into a engine with no timing marks on a tab... I never had one.. Always used this ol ratty looking thing I have had for years...
lynnboy021
lol hey what do you think of my specs are they good?
lynnboy021
a omc manual it does not say what year it covers but the wire diagrams are the same on my motor
Joshua Nichols
LOL that helps... I looked and they show different specs for different years.....
lynnboy021
hey thanks for your help but i dont know what time its on your end but its 3:15 her in ma and i need to wake up at 10 am so talk to you later..
bruceb58
Buy the timing light with the advance feature. With that one, you can determine if the distributor is giving you your correct total advance. It also makes setting the timing way easier because you only need to find the the TDC mark.
Make sure you use a dwell meter when setting your dwell and set it first before you adjust your timing.
Your dwell angle and timing specs are correct.
Regarding your dipstick and tube, OMC changed those many times over the years including what threads were on the pan. You have the original tube now? These dipsticks/tubes are one of the irritating things you are going to be up against with OMC being out of business.
lynnboy021
advance of 29 at 3000rpm? sorry dont know anything about advance
bruceb58
The distributor increases the advance over RPM. That is why I recommend getting the advance timing light. In the manual, there is a chart that shows what the total advance is vs RPM.
