5.7 Intermittent starter click
Strecker25
Hi guys, on one of our 98 5.7 EFI's I have a new intermittent starting issue. If I press the ignition, especially on a cold start, I hear a click. If I turn the switch off and back on the starter engages and cranks strong and starts the motor. Turning the engine off, giving it a few minutes, and trying again I have to again engage the switch (hear the click) turn the switch off then back on and the motor fires. Connections are tight at both battery and starter.
I ordered a new slave solenoid, am I headed in the right direction? I wasnt able to verify where the click comes from but I believe it to be up top at the slave solenoid.
Of course we have a big trip coming up Wednesday so this had to become an issue now
Thanks everyone
a few things that can cause the starter to click, then work fine. none of them require waiting a few minutes
it could be your bendix pushing the pinion tooth directly onto a ring gear tooth. then the next time it moves just enough to engage - not much to do about this
it could be the bendix solenoid on the starter is carbon arced and not always making contact - this would require a new bendix solenoid (starter must come out)
it could be your pilot relay is corroded or carbon arced and not always making contact - this would require a new pilot solenoid
you basically need to identify what is going click.
Strecker25
Thanks Scott. I will get down there today and verify where the clicking is coming from. I do believe it was from the top of the motor where the slave/50a breaker is. It is a "soft" click.
Ayuh,.... Tight don't mean corrosion free,....
Pull apart those connections, as well as the rest of the "Start" circuit, sand 'em to shiny metal Clean, 'n reassemble 'em,.....
I coat 'em with grease to keep 'em corrosion free,....
Strecker25
Thanks guys. I replaced the slave solenoid tonight and all is well. The ring terminals were just a bit chalky so I cleaned them up nice. The combination of the slave solenoid and fixing the connections has her cranking on the first try now.
