5.5 pinion gear (shock absorber)
frank27
anyone know were to get a good used one or know anyone that will part with one thanks
boobie
Re: 5.5 pinion gear (shock absorber)
Try the Top Secret Files at the begining of this forum and look for salvage yards.
64osby
I have heard that people will trim the length to fit proper and weld the shaft to fix a bad shock shaft.
boobie
I've done that also and it does work.
Steve A W
If You weld it You need to change the "drive" pin for a "sheer" pin.
samo_ott
I haven't done it but plan to on the next one I come across.
