5.0 mercruiser, quick question
tcross34
2005 5.0 mercruiser.
On the top of the front part of the motor there is a bicycle pump looking gadget.
It sits in its on holder and can be taken off and looks kinda like a bicycle pump.
Anybody have any idea what it is? I asked the boat mechanic at the shop and he had no idea:eek:
Re: 5.0 mercruiser, quick question
Ayuh,... I believe it's probably apart of the elaborate block drainin' system used on some Mercs...
I haven't seen 1, but I'm sure somebody'll be along who Has....
Oldskool
Block drain would be my guess as well. My 2007 5.7 has one, and it has a knob on top that you can turn counter clockwise for an easy drain of water when you're ready to winterize it.
tcross34
Here is a pic.
This is standing on the stbd side from the rear looking forward.
I took the "pump contraption" out of the clips that are just to the right in the pic. It justs sits on top in those clips and can be taken out. No hoses or wires attached to it. I also extended the pump out a little to see that it "pumps" just like a standard bicycle pump.
Any ideas??
UNSUREBOATGUY
Looks just like the little bike pump I have to pump up my kids' various footballs, basketballs, etc. Used to clip on a bike frame for emergency innertube repairs.
UNSUREBOATGUY
Do the boat trailer tires loose air a lot? Would only take 2000-3000 pumps to fill 'em back up:D
45Auto
Those air pumps only come on the models where they hide a blow-up bikini doll under the seat so you look cool when you blow it up and place it on your sundeck ....
Actually, Bond-o and Oldskool win the prize - it takes about 30 seconds to drain your engine for cold weather with it, just make sure everything is draining and not clogged up:
burp
tcross,
In your picture, just to the right of the blue portion of the pump, is a blue colored cap. Just above the blue colored cap is a brass release valve with a ring on the end of the release valve. The white and green tubing will run down to the drains which are mounted on the sides of the engine.
What you have is a single point drain on your engine. Remove the blue colored cap and connect the hand pump. Pump it a few times and you should see a couple of little indicators pop up near the release valve and water will be expelled into the bilge from the single point drains the sides of the engine. Once the water is expelled, pull the ring on the release valve, the little indicators will retract and the single point drains should close.
One word of caution......I would advise NOT to use the single point drain with the boat setting in the water. A boating buddy of mine routinely did so on his 496 MAG engine. One Monday morning, he got a call from the marina as the boat had sunk while tied up to the dock. The cause....one of the single point drains mounted on the engine was located at or below the waterline. The single point drain did NOT fully close and thus water enter the boat through the partially open single point drain. The bilge pumps drained the batteries and the boat sank tied up at the dock.
On the 496 MAG engine, the single point drain on the starboard side of the engine is located and connected to the hoses between the outdrive and the raw water pump mounted on the front of the engine. Thus if the single point drain is below the water line and does not fully close.....water will enter the boat. The drain on the port side is located above the water line and should not cause any problems if it does not fully close. The drain valve locations on other size engines could be located differently from those on the 496 MAG engine. Just be aware that the potential exists to create a bigger problem if the drain valve doesn't fully close and the boat is setting in the water.
