Houdini_1980
Thread starter- Joined
- Jul 20, 2017
- 2
Hey guys. First post here. Got some info on setting up the carb on this 4W71D that I had given to me. Was told it ran good at high speed but wouldn't idle. Hasn't been run in almost 10 years. Cleaned it up, rebuilt the carb, does not have cork float. Replaced the impeller and spark plugs and tried setting the carb. Had a heck of a time at first. Realized there was fuel/oil in my test tank and it was only firing on one cylinder. Both coil housings were cracked and arking on the flywheel. Replaced coils and condensers. I haven't replaced the points yet as they are nice and clean looking, but I do have them. (Just a little background... I'm an automotive mechanic, 20 years total experience but a little new to 2 strokes.) After that repair, I had it running great in the test tank. Took it out for a spin on the lake and it would not start... :facepalm:
I just took it apart again tonight as I thought the float had stuck a bit as there was fuel coming out the front of the carb. Carb and float look good, moving freely, bulb gets solid when pumping it up. I pulled the spark plugs and they were dry. I had good spark so whatever fuel was getting into the cylinder was being burnt. I also checked to see if I had compression and vacuum with the plugs out. I indeed had both. I had it running briefly with the last pull of the rope as it broke off, but it died after about 5 seconds of running. I am going to bring my spark tester home this weekend just to make sure I have a good strong spark, but I think it may be a fuel issue. Any other ideas would be welcome.
Thanks for any info guys!
