Sasmaster6000
Thread starter- Joined
- Mar 5, 2017
- 1
Hi everyone! First off, I apologize for breaking forum etiquette and asking a rookie question which I'm sure has been answered several times before. I did search the forums and have since learned may things which pertain to my situation but I still have questions (I realize there is a thread for a similar unit but I don't want to hijack someone else's inquiry).
So, I have become the owner of a 1973 4HP Johnson Seahorse (4W73C) which has been in the family since it was new. This motor was last in the water 25 years ago and has since been in uninsulated storage (Hot western summers/ freezing northern winters). The motor ran fine at the time and was test started roughly 10-12 years ago before being sent back to storage. I would like to prep the motor for regular use. I know I should replace the impeller, coils, plugs and fuel lines along with the most obvious lube changes in addition to rebuilding the carburetor. Due to its age and infrequent use, I'd also like to change all the gaskets and O-rings to ensure like-new operation. Visually the motor looks good, despite some chipped paint on the cover. The propeller / lower unit is also in good condition and doesn't have any dings/scratches.
My question is, what else should I look at replacing since I will essentially have the majority of the motor disassembled? Should I put in new piston rings? Also, what recommendations do you have in regards to upgrading/ modernizing this motor? I appreciate any and all advice!
