4HP Seahorse
Sasmaster6000
Hi everyone! First off, I apologize for breaking forum etiquette and asking a rookie question which I'm sure has been answered several times before. I did search the forums and have since learned may things which pertain to my situation but I still have questions (I realize there is a thread for a similar unit but I don't want to hijack someone else's inquiry).
So, I have become the owner of a 1973 4HP Johnson Seahorse (4W73C) which has been in the family since it was new. This motor was last in the water 25 years ago and has since been in uninsulated storage (Hot western summers/ freezing northern winters). The motor ran fine at the time and was test started roughly 10-12 years ago before being sent back to storage. I would like to prep the motor for regular use. I know I should replace the impeller, coils, plugs and fuel lines along with the most obvious lube changes in addition to rebuilding the carburetor. Due to its age and infrequent use, I'd also like to change all the gaskets and O-rings to ensure like-new operation. Visually the motor looks good, despite some chipped paint on the cover. The propeller / lower unit is also in good condition and doesn't have any dings/scratches.
My question is, what else should I look at replacing since I will essentially have the majority of the motor disassembled? Should I put in new piston rings? Also, what recommendations do you have in regards to upgrading/ modernizing this motor? I appreciate any and all advice!
oldboat1
family heirloom! Think I would change out the impeller first and drain the gearcase. Then might pressure test the case.
F_R
Honorary Supreme Mariner
My advice is don't over kill. Meaning don't go into it that deep unless you have good reason to. As for upgrading or modernizing, the old design is just as good, maybe better than some newer stuff. Those 3 & 4hp weedless motors were some of the best motors ever built.
GA_Boater
Gotta agree with the guys above and add one thing.
Look at any hoses under the cowling. Age, especially lack of use, causes hoses to harden and crack.
tpenfield
If it ain't broke, don't fix it . . . I would take the spark plugs out and get a peak inside the cylinders. See if there is rust. If that looks OK. put a little bit of 2 cycle oil in the cylinders, just to add some lubrication and 'free spin' the engine with the pull cord.
The impeller change sounds like a good idea. and maybe run some carburetor cleaner through he fuel system. Other than that . . see if you can get it to start. If you go about replacing coils, etc, you'll tend to spend too much money. I'd only replace the ignition stuff if it really needed it.
I think the flywheel should be taken off.--Likely the coils are cracked.----New coils are cheap for that motor.
