aarons 470
Thread starter- Joined
- Aug 29, 2012
- 351
Hello All.
I am rewiring most of my 1977 Cobia boat, and tracing the rest. It has a Mercruiser 470.
The Tachometer has three wires coming off of it studs.
One is pink or peach in color, connected on the positive side of the tach. I believe this goes to the coils positive side?
Then there are two ground wires. One has a common ground connection to the other gauges in the panel.
My other question is the other ground wire. It is a bigger wire, 10 gauge. It comes off of the tachometer brown, then goes to a harness behind the dash. After that there isn't a brown wire. So I am not sure which wire it is that continues.
Does anyone know where the larger ground from the Tach is connected to? Can i just ground it to a solid ground, or is there a special place it needs to go to in the engine area etc?
Thanks
Thanks
