470 start issues
2fishy4u
Hi guys, I paid a local mobile mechanic to install a new long block. He final had everything ready for a test start. It will not fire. The only resemblance to firing is a muffled backfire out the rear. He is stumped. I checked for spark, plenty of spark. Plenty of fuel. But will not fire. Anyone got any ideas where to look. Like I said it does a muffled backfire instead of firing.
Bt Doctur
sounds like the dist was put in the wrong spot. go back to basics,.
#1 at TDC compression, drop in dist with the rotor aligned to a cap contact, firing order 1,3,4,2 cylinders are front to back 1,2,3,4
wrench 3
The timing marks will line up on either #1 or #4. So you will need to psychically check for #1 building pressure to get the right one.
2fishy4u
Thanks guys, that was my thoughts. He just swears he did it right. Heading out there now to check myself
Maclin
Back in the last century I was replacing spark plug wires on a 4 cylinder, and got all dyslexic when I had momentarily held the cap upside down and got the wires 180 off on the cap. Like has been mentioned, basically start over and check everything related to timing set. If it ends up being ok on distributor and wires orientation then could be cam timing is off. A basic compression check would show if that is a problem or not.
2fishy4u
Thanks for the help guys, he was counting the mark on the flywheel as TDC............ he was on cylinder #3 TDC. Used a compression gauge and got it on #1 then dropped it back in. Set the cables right, and she fired up.
Maclin
Good deal :thumb:
They work on a lot of different engines and that one is a little different than mainstream, and that can catch them offguard sometimes..​Glad you had a good mechanic that backed up their work.
