470 shift interrupt and trim senders wiring
Rake722
Evening all,
my 470 has never had the interrupt or sender wiring connected and I’d like to fix that.
the loom has 4 wires emerging from the rear. A pair of gray terminated to the same ring connector and a single brown and single black with no connectors on.
I’d like to ask which is which and how to connect them ?
i have both trim limit and trim sender but can’t for the life of me find anything to connect them to.
thanks in advance
achris
More fish than mountain goat
'Trim sender' is for the gauge and joins a wire that goes directly to the 10 pin instrument harness plug. 'Trim limit' goes to a pair of connectors in the trim pump wiring harness...
Shift interrupt switch should have 2 wired, one that runs to ground (black), and the other goes to the coil- terminal.
Chris...
