nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,093
So this year prior to putting the boat in the water I did some outdrive maintenance. Replaced the water hose, trim senders, ujoints, bellows, shift cable. Pressure tested the drive and had an upper seal leak. Replaced them, speedi-sleeved the grooved drive shaft. Pressure tested again, now had a leak at the shift shaft seal. I swapped the gear housing with another that I had--I had less than 10 hours on this unit since replacing the impeller 2 years ago, and I didn't check the impeller prior to reassembly this time around.
Since getting on the water, the gauge has been reading hotter than usual (160 v. 145-150). Only under load, >3300 rpm, prolonged running.
1. I checked the new water hose, doesn't look kinked. Anything else I could have screwed up with that?
2. I just removed and cleaned the heat exchanger. Hadn't done that in a loooong time. It looked pretty good. I'd be surprised if that was the issue.
3. Pulled and tested the t stat. It was as open at 182' as it was at 212' (or really close). Not sure if it's opening all the way though? Pic below.
4. Replaced the reservoir/exhaust mani gasket. I noticed some coolant residue around the gasket. The reservoir and manifold looked pristine, surfaces flat.
What I haven't done yet:
1. Replaced the impeller. I'm tired of pulling the damn drive. I'll do it, but don't feel like it.
2. Verified that I'm actually overheating. I have a radiator cap with a built in gauge, and an IR gun. I haven't been able to get back on the water to check them out. Up to 210' is normal per the book.
3. Checked the impeller output. This looks difficult and imprecise enough that I'm not sure it's worth doing. I can run all day at 3k rpm and be fine. My gut tells me that an impeller problem should show up under less stress than what I'm seeing, but i don't know if that's true.
