nola mike
- Apr 22, 2009
- 5,980
I've had a leak on this thing damn near since I bought it 5 or 6 years ago. When to start it for the first time. Pulled the valve cover, all looked fine. Pulled the plugs and turned over, and...a/f gushing from #4. Is there any place other than the riser/mani interface that this could be leaking? The riser is a couple of years old. I had the manifold surface machined when I replaced the riser. I'm not sure if it ever completely stopped leaking, it isn't really noticeable unless it sits for a while. I tried to ignore it last year, but would like to fix it this season (again). I hate draining the whole damn system--I think I'm going to pressure test, drain coolant, and repeat until I hear the leak. If it's that gasket interface, I figure I should be able to hear it right away. Trying to see if I'm forgetting a potential leak point here.
