460 king cobra lil spit and sputter
211libwtfo
When I'm cruising and want to make a trim tab adjustment my engine will give a spit and sputter will I'm pressing the trim tab buttons. Is this an electrical issue low amp alternator voltage regulator. Any help is appreciated
Ayuh,..... Check, 'n clean All the ground connections, startin' at the battery's (-) terminal,.....
211libwtfo
It's a bit of a mess down there as far as wiring. So I bet your right. Thanks. I'm an electrician by trade but HATE auto wiring
jerryjerry05
Like Bonbo suggested a bad ground.
​Or the solenoid is going bad.
The wiring harness from the dash.
Clean the contacts.
211libwtfo
Thanks jerry under the dash is really messy also plus the depth finder is un hooked and I need to get my radio installed.
HT32BSX115
One of the problems I noticed with mine was several of the wire connections were corroded. I had to cut several connectors off and crimp new ones on. It made several 'things" work that didn't work before. Many boat manufacturers didn't seal crimped connections very well........Go figure:rolleyes:
211libwtfo
Thanks rick you're a staple in here. Somebody has been under the and made a mess rpm gauge is iffy speedo?able temp gauge seems good trim gauge nodda depth disconnected ignition switch loosy goosie soo that's gonna be a good place to start. I really enjoy boating and with this older liberator I REALLY enjoy the info on this site.
HT32BSX115
When I swapped the engine, I used the complete boat harness from the Mercruiser Bayliner when I put it back together. So I completely rewired everything. I also installed a fuse "block" under the instrument panel so they'd be easy to access.
Similar to the one below:
It uses those modern automotive type fuses that are different colors for different ratings.
http://www.iboats.com/ATC-FUSE-BLOC...1920448--session_id.799411406--view_id.980993
Lou C
Years ago when I first got my boat I had the same problem. Cured it by replacing all the crappy automotive grade battery cables when I put in a dual battery system about 10 years ago.
211libwtfo
It'll be a winter project but my dash panel has the toggle switch with the fuse next to the switch how does this differ from the fuse block you speak of rick. Planning on jus installing a whole new rocker switch panel.
And lou C this boat has a dual battery set up with large gauge wire. But I'm gonna guess its corrosion somewhere.
