Searay260cc
Thread starter- Joined
- May 5, 2011
- 32
My 89 searay had a 454 Merc. It seems like it take a 142 degree thermostat. The mechanic put a 160 degrees thermostat in it. Does it matter which one it is?
- Is there a difference in length between a 140 degrees thermostat and a 160?
-When he put the 160, he put the o-ring first then the thermostat sits on top but there is a space between the top of the thermostat and the cover. Should the cover have metal piece that would hold down the thermostat or
-The 140 degrees thermostat has a higher top that goes right against the cover?
- Do I need a sleeve that sits on top of the thermostat and when i put hte cover ,it secures the thermostat firmly in place?
