40hp Johnson Fuse?
Snowfish
Is there a Fuse or Fusible link in a 1985 40hp Johnson?
Model J40TLERE
Sn# G03532642
If so, where's it hiding?
Snowfish
Re: 40hp Johnson Fuse?
Yes! I may have seen that, but didn't recognize it. Thanks. I'll dig around, on the starboard side, by the terminal block. I bet it's hiding under some "spaghetti".
Daviet
Look around, I am sure you will find it.
Snowfish
Thanks again Commander. What a great place this is. Wish I could contribute more. So far I've just been on the receiving end.
Daviet
Keep hanging around and someone will have a problem that you have already solved, and you will be able to help them the way others helped you.
Every one here is a great source of information and has a lot to contribute.
Snowfish
Thanks to You, and the Forum, it took a whole 45 seconds to find the fuse! Sweet!
Thanks.
retiredfornow
Any idea what color the fuse wire is? My wiring diagram doesn't show a fuse in the system.
Daviet
retiredfornow, are you working on the exact same engine as Snowfish? If so click on the link in post #2. Otherwise if you would start a new post with your model number I am sure someone will help you.
Snowfish
Not sure what the wire color is. Didn't look. But if it's the same motor the fuse is in the front of the powerhead just port of the plugs. It looks like a connector, but isn't. Sealed up pretty good, but really easy to get to. Just pull the cover, look down to the left (port side) by the plugs and disconnect the first connector that you find. Bet there's a 20amp fuse in there.
