seamule1
Thread starter- Joined
- Oct 7, 2007
- 20
My 2000 40hp yamaha 4 stroke recently had the alarm go off and the rpms dropped like they are supposed to. When I got home I found that the temp sensor was broken where it screws in the block (plastic fitting). I ordered a new sensor and removed the broken piece that plugs into the harness. Waiting for the new part to arrive, I took the boat out today but couldn't get past idle and the alarm went off. My question is this....does removing or unplugging the sensor still cause the alarm to go off or might there be something else causing it to go off? The tail tell is working fine and it does not overheat...I can put my hand on the block while running. Thanks for any input!
