40 mariner outboard
chatay
I installed a tachometer on my 1989 mariner 40 HP outboard. Now I'm blowing the main fuse on the motor. Can any one tell me why
chatay
Re: 40 mariner outboard
A 7000rpm faria marine tach and I used a wiring harness to plug into my control box. Purple wire is hot black is ground and gray is signal by the directions. The tach will operate for a few minutes then the fuse will blow. It's not instantanious. It takes a few minutes before it blows the fuse
Barnacle_Bill
Make sure that is a 20 amp fuse. If it is temporily disconnect the purple wire and try it again. If you no longer blow the fuse you have a defective tach.
water world
unplug harness from control box to dash. then check. check engine alone. then boat side.
Texasmark
Slowly blowing the fuse, regardless of what size, says that you have an overload of current just above the rating of the fuse, as compared to a short circuit which would blow it instantaneously. With that said, and if it is a 20 amp fuse then you are pulling a little over 20 amps.
Well sir at 1 ohm 20 amps would take a 20 volt battery which you don't have. Thinking through this as I type: so for 12v and say 21 amps, the resistance would only be 12/21 = 0.57 ohms. The lead resistance of your ohm meter would be on the order of 0.3-0.4 ohms and the wiring to that tach is probably 20 AWG for another 0.3 or so ohms, so you could have a short circuit in your tach and not be able to recognize it for the reasons given.
Wiring to the tach should be: purple (12v) input, black (ground...battery - term), and grey (tach) input. Pins on tach interface plug: Purple pin A, Grey pin B, and Black pin D
Go to the back of the tach and measure the resistance across the purple and black terminals and ensure that it is something greater than 5 ohms with the ignition off.
Then, change to DCV on the meter, turn the switch on and measure the voltage at those same terminals.
Come back with the results. Oh, and the size of the fuse that you have been blowing.
Mark
water world
disconnect plug from control box to dash. if that fixes it its in the dash. if it still blows fuses check control box.
