this e40elcud engine quit on the lake and wouldn't restart. after towing in, I found the plugs were wet. a day later and a new set of plugs and about two 30 second sessions on the starter and it fired. it has a rough idle, but pulls fine from 1/4 throttle on. the next day it took two more 30 second sessions on the starter to get going with choke until it fired then no choke and full idle trim. idle is still rough, but better even after 10 minutes warmed up under load. any ideas for a better idle and less wear on the starter??? needle and seat? ignition glitch?? (fuel is two weeks old)
