4.3l Oil Reservoir ?
tahoejag
Use of gear lube in relation to reservoir bottle? Beginning of season bottle was topped off. After aprx two months of boating (average 50-60 hrs) reservoir bottle is very low - at the add point. Is this normal for the drive to "use oil"? Or are their issues to be looked at?
2006 4.3l carb raw water cooled
alpha I gen II 1.81:1 ratio
14 1/4 x 21 3 blade MW
Brewman61
Ensign
Re: 4.3l Oil Reservoir ?
Normal for the drive to "use" lube? No, that'd indicate a leak.
What often does happen is that after you push all of that lube into the lower unit, thru the hose to the resivior bottle, air gets trapped.
Using the drive for a bit "burps" out some of this air and then the lube level goes down in the bottle a bit.
I'd top it off and see if it continues to drop, if it does, you might need it checked. If not, then it was possibly the air burping out thing.
tpenfield
Maybe pressure test the drive, but I have always experienced some usage of the outdrive oil.
achris
More fish than mountain goat
Those drives do have a habit of burping air up, as someone said. It's because when the drive is filled from the bottom there is a pocket of air above the vent screw in the upper half of the drive that can't be filled. As the drive is used that air gets slowly purged through to the reserve bottle. Hence the level goes down.
When I service an Alpha One gen II drive I fill it in the conventional way, then lay it on the ground, port side up, and then slowly continue filling through the vent hole in the upper. That gets as much air out as possible, and stops the 'my drive's using oil' problem.
Chris....
tahoejag
Thanks guys! All makes sense to me...did split the lower for new impeller last spring and changed out lube. Will keep eyes on it.
