4.3L motor replacement
Chicken Joe
I searched for any related threads, but found nothing to help.
I just purchased an 88 celebrity 190vbr with the 4.3L in it. The block & 1 manifold is cracked & I'm looking to replace the long block. I came across a really good deal on a votec 4.3L out of 2000 gmc sonoma. I have compared specs between the 2 & it looks like the Mercruiser engine has a much larger camshaft. That brings me to the 1st of several questions: Can I swap the camshaft from the the Mercruiser engine into the Vortec engine? (Journal size looks to be the same) 2nd question: Are there any concerns with the Vortec engine working with the marine set up? 3rd question: Is there a balance shaft issue with this swap?
Any concerns at all that I haven't asked about?
Thanks
Alpheus
Re: 4.3L motor replacement
There is a balance shaft issue. Non balance shaft parts can not be swapped into a balance shaft block. Also the cam in your older engine will not work with the Vortec setup because it has a roller cam and yours is not. Read my restoration thread. I just built a 4.3 and swapped in Vortec heads. It should answer allot of your questions...
Chicken Joe
My Mercruiser is a roller motor. Not wanting to swap parts from the votec motor to the mercruiser motor, just the cam from the merc motor to the vortec.
Chicken Joe
Why won't it work? Journal size is identical. Not trying to be arguementative, just trying to understand why not.
Ayuh,... Because there's a world of difference between an 88, 4.3l, 'n the 2000, 4.3 motor....
The 2000 has the balance shaft above the cam...
Chicken Joe
Well after digging into both motors, I found out for myself that there's alot of differences betwen the two engines & it looks like I will be in need of another engine. Anybody have a used 4.3L that will work in my application for sale cheap? If so please let me know.
Thanks
Ayuh,... I agree Bubba, with abit of adaptin' that motor will work just Fine...
Off the top of my head, an electric fuel pump will be necessary...
