Rhinodecals
- May 21, 2012
- 20
I have seen a number of posts on this problem and thought I would post anyway. I just did a Carb Kit rebuild today it will start up the run for 10 to 15 sec. then die. I am new to the boat world worked on a lot of car engines in my passed. It has been an long time scents I did a rebuild and not sure if I got choke arm in the correct positions. When the boat is in the not running the butterfly level should be in the close positions on the carb is that correct. I got it running this afternoon and came back about 4 hours later and it started doing the same thing again. gave up because it got dark and I was about to hit my head on something!
